[SOLVED] Whats the difference between Sapphire Radeon RX 5700 XT PULSE and Sapphire Radeon RX 5700 XT NITRO+.
Oct 15, 2019
6
Hello,
Which one do you recommend and why?
Thanks.
The Nitro has a better cooler and VRM, thus it has slightly higher stock clocks and possibly more overclocking headroom versus the pulse. Linked a review of the nitro and pulse below. If the price difference is not very large I would get he nitro, if not I would watch the reviews and decide if paying extra for the nitro is worth it to you. In terms of performance they will be nearly the same, slight edge to the nitro.
Nitro:
View: https://www.youtube.com/watch?v=kh1DeO4yz2s
Pulse:
View: https://www.youtube.com/watch?v=FQJCm7bnOfU
Nitro:
Pulse:
I don't know if its to big for your case as I don't know what case you are using.
Too heavy? Too heavy for what? I don't see why that would be a concern.
it doesnt matter my case, im not worried about the dimenstions
but im worried that the PCI port, and a screw at the GPU's ports would not support the Nitro+
