Tweed Reputable Aug 14, 2014 282 0 4,780 Apr 5, 2016 #1 https://pcpartpicker.com/parts/compare/corsair-cpu-cooler-cw9060020,corsair-cpu-cooler-cw9060021ww/ Corsair H100i gtx
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Apr 5, 2016 #2 280mm variant vs 240mm. One has two 120mm fans, the other has two 140mm fans (and requires the mounts for them as well on the case) Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,750 22,087 184,590 Apr 5, 2016 #3 What about those specs is not clear? CFM, fan speed, noise level, size, price. Upvote 0 Downvote
Tweed Reputable Aug 14, 2014 282 0 4,780 Apr 5, 2016 #4 My case is the InWin 805. Does it matter which one I get? Which do you recommend and why? Performance is the same? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,750 22,087 184,590 Apr 5, 2016 #5 Tweed : My case is the InWin 805. Does it matter which one I get? Which do you recommend and why? Performance is the same? "Which one" depends on why, the size of the case, and the rest of your parts. Upvote 0 Downvote
Tweed Reputable Aug 14, 2014 282 0 4,780 Apr 5, 2016 #6 http://pcpartpicker.com/p/cy44XL Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Apr 5, 2016 Solution #7 http://www.corsair.com/en-us/cooling/cpu-coolers CPU Coolers Upvote 0 Downvote Solution
