Question What's the optimal fan curve for a 6650 XT using AMD Radeon software ?
It mostly depends on how good the cooler is. If the cooler is good, you can just leave it to default and call it a day. If you are getting high temps under normal use, then do as CountMike says. If it gets too hot and throttles, then you should underclock and undervolt it.
Reactions: CountMike
I have undervolted it, but whenever i restart my PC, the GPU profile goes back to default.
Optimal is a subjective measure and depends on multiple factors, particularly your system's cooling/airflow setup. whether OCing, how much noise can you tolerate, etc.
Except for the most extreme of circumstances, you should not have to underclock/undervolt to maintain sufficient cooling.
With everything at stock settings, what are your CPU and GPU operating temperatures at idle and under load?
Latest posts
