What's wrong? Please help
Shvarz
23
I posted this message in "Windows" section, but was told that my problem might be the HArd-Drive (as I somewhat suspected). So here I repost that message, sorry for cross-posting.
Here is what happened: One day I turned my computer on (speck are below), and it started loading windows really slow and HD was making these regular noises (which could be the formatting drive noise, I am not sure). At first, I thought, that something is up with my memory or HD, turned off the comp, checked connections and restrated. It was doing the same thing "Loading Windows" appeared and stayed on the screen for a long time. Then it changed to some DOS commands from my start-up files and then it said: "Now you can restart your computer". When I did that, I got "Non-system disk" error. Drive D, which is a separate partition on the same HD was OK. I had to start my comp with Windows CD-ROM and install fresh Windows.
Well, good thing is that I back-up my whole system every month, so I just restored the back-up i did (luckily) just two days before this crush. In about one our I had my system back.
It stayed that way for 4 days, then it happened again. This time I did not get "Now you can restart your comp" message, just "Could not read C: drive, Abort, Retry, Fail". I could not install Windows from CD-ROM, cause it would say that the drive may have operating system on it, and it did not want to proceed. I had erase the partitiona and format it again, then install windows and restore back-up.
What do you think of it? Virus? Windows bug? hardware glitch? How do i figure it out?
My specs:
AMD K6-2-plus 500 (at 550), ASUS P5Ab, GeForce2 MX from ELSA, 128Mb RAM, WD 18Gb 7200 Expert HD, split in two partitions 9 and 9 (had it for more than 6 months), Windows98SE. Office 2000, Norton 2000. just thaught I should mention that Norton DiskDoctor always complains about free-space being not reported correctly, sometimes I say "fix it", sometimes - not, but it reappears at random intervals. Also, from time to time it says that the boot record was changed and asks me to restore it, again I do it sometimes. I just thought about it as bugs in the prog, but now I'm thinking maybe there's something wrong with HD actually?
Thanks for any help.
I would say that I wouldn't restore that backup again and just try a fresh install of windows. Something seems to be hosed in the OS! I mean you said you backed up a few days prior to this crash and then you restore your backup and fours days later 'BAM' you are having the same problem.
FORMAT C: >>> Thats my thoughts! *:O)
<font color=green>"Your call will be answered by the next available Tech Support representative"</font color=green>
Well, why do you think it is the OS to blame? It could be a virus in one of the programs. It could be faulty HD. It could be some other crap. For example, when I bought a new case for my comp, I just moved everything from one case to another and suddenly I had a comp, that was totally dead, it would not beap, it would not post, nothing. After two days of messing around with it, it turned out to be a problem with sound card, which, for some reason, did not fit perfectly into the case's boundaries and was a bit bent from me screwing it to the case.
I just hope someone recognizes the symptoms for what they are (there's a lot of knowledgeble people in this forum) and helps me out.
And, yes, I thought of reinstalling everything from scratch, but it will be a lot of pain. Unlike some people I do not re-install windows every couple of months, I had this install for almost two years now. I've tweaked and customized so many things in it to fit my needs, that I would not know even where to start with fresh install. I've probably deleted some of the programs, I used for tweaking too. Also, I have a bunch of programs in whic the interface is customized to my liking as well: All Office programs, Photoshop, Dreamweaver and so on...
I am almost praying for an easier solution here.
Well - the symptoms you describe are similar to those of installing a new application, but it usually says so when it is doing it.
What are you using Norton Disc Doctor for? From what I have read it is garbage and causes more trouble than it fixes. Try disabling that as well.
Something appears to be writing over your boot partition. Create a bootable floppy, and next time see what partition is active (are both primary, or is 1 extended with a logical volume in it?)
Pete
-* This Space For Rent *-
email for application details
Disk Doctor is OK for checking HD for allocation errors and such. I've been using it for 2 years now, never had a problem, other than this time. You are right, I have two partitions, C is active, D is extended with logical volume in it.
Thats the sort of problem you can spend weeks trying to diagnose and end up back where you began, The best thing would be to wipe the hdd, redo the partitions and start again, you solve 95% of probs that way
