[SOLVED] Whats wrong with my rgb fans or hub?
Dustin Jacocks
62
Hello, I recently put together a build with 5 corsair sp120vpro rgb fans and the core rgb hub. Hub is connected via data and usb to motherboard. All 5 fans are connect 1 2 3 4 5 order. The thing is. Only my 1 fan works. All components are brand new btw. In corsair icue I put it to 5 sp pro fans. Also tried using my lighting node for rgb strips and another hub for the fans. Connected the node to the hub as well. Hooked the usb to motherboard and fans to the hub correctly. And still nothing. Seems like they're connected and seen in corsair link and icue but only the 1 fan works. I'm so confused. Thinking of getting the pro and connecting everything to that and see if it works.
