Hi, I am getting whea_uncorrectable_error on my Surface pro 4 (6 months). I am getting it, since the beginning, but rather infrequently. I got the error like 10 times in the six months I own it. I got it today and decided to see what's going on. I am including the Bug Check Analysis and I need somebody more knowledgeable to confirm what I am reading. Is the Cache Processor to blame?
Pls note that I have used Intel's Processor Diagnostic, which reports no errros. Bug check analysis follows:
Thanks
Microsoft (R) Windows Debugger Version 10.0.16299.15 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\gatzo\Downloads\121617-12250-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
WARNING: Whitespace at start of path element
Error: Empty Path.
Symbol search path is: srv*c:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 16299 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 16299.15.amd64fre.rs3_release.170928-1534
Machine Name:
Kernel base = 0xfffff802`5348e000 PsLoadedModuleList = 0xfffff802`537effb0
Debug session time: Sat Dec 16 10:19:52.627 2017 (UTC + 2:00)
System Uptime: 0 days 20:30:58.489
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, ffffbf0112070028, be000000, 100110a}
*** WARNING: Unable to verify timestamp for IntcAudioBus.sys
*** ERROR: Module load completed but symbols could not be loaded for IntcAudioBus.sys
Probably caused by : GenuineIntel
Followup: MachineOwner
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffbf0112070028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be000000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000000100110a, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.16299.64 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER: Microsoft Corporation
SYSTEM_PRODUCT_NAME: Surface Pro 4
SYSTEM_SKU: Surface_Pro_4
SYSTEM_VERSION: D:0B:08F:1C:03P:38
BIOS_VENDOR: Microsoft Corporation
BIOS_VERSION: 108.1866.769
BIOS_DATE: 10/10/2017
BASEBOARD_MANUFACTURER: Microsoft Corporation
BASEBOARD_PRODUCT: Surface Pro 4
DUMP_TYPE: 2
BUGCHECK_P1: 0
BUGCHECK_P2: ffffbf0112070028
BUGCHECK_P3: be000000
BUGCHECK_P4: 100110a
BUGCHECK_STR: 0x124_GenuineIntel
CPU_COUNT: 4
CPU_MHZ: 8a0
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 4e
CPU_STEPPING: 3
CPU_MICROCODE: 6,4e,3,0 (F,M,S,R) SIG: BA'00000000 (cache) BA'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: dwm.exe
CURRENT_IRQL: f
ANALYSIS_SESSION_HOST: SURFACEVAGS
ANALYSIS_SESSION_TIME: 12-16-2017 12:40:46.0164
ANALYSIS_VERSION: 10.0.16299.15 amd64fre
STACK_TEXT:
ffffae00`a6c0c5c8 fffff802`5344af1f : 00000000`00000124 00000000`00000000 ffffbf01`12070028 00000000`be000000 : nt!KeBugCheckEx
ffffae00`a6c0c5d0 fffff806`770a148a : ffffbf01`12070028 ffffbf01`0ff29040 ffffbf01`0ff29040 ffffbf01`0ff29040 : hal!HalBugCheckSystem+0xcf
ffffae00`a6c0c610 fffff802`5370ed41 : ffffbf01`12070028 00000000`00000000 ffffbf01`0ff29040 ffffbf01`0ff29040 : PSHED!PshedBugCheckSystem+0xa
ffffae00`a6c0c640 fffff802`5344b460 : 00000000`00000728 00000000`00000001 00000000`00000000 ffffbf01`0ff29090 : nt!WheaReportHwError+0x261
ffffae00`a6c0c6a0 fffff802`5344b7c0 : 00000000`00000010 00000000`00000001 ffffae00`a6c0c848 00000000`00000001 : hal!HalpMcaReportError+0x50
ffffae00`a6c0c7f0 fffff802`5344b6ae : ffffbf01`0ff28b60 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerCore+0xe0
ffffae00`a6c0c840 fffff802`5344b8f2 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandler+0xda
ffffae00`a6c0c880 fffff802`5344ba80 : ffffbf01`0ff28b60 ffffae00`a6c0cab0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0xce
ffffae00`a6c0c8b0 fffff802`535fc7fb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
ffffae00`a6c0c8e0 fffff802`535fc56c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7b
ffffae00`a6c0ca20 fffff806`7aeed97b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x1ac
ffffae00`a6c1ae80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : IntcAudioBus+0x1d97b
THREAD_SHA1_HASH_MOD_FUNC: fd23acc635c95369845545ab6491c5a7ece55d8f
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 23850cb567dbc00f9bc36c9cda8f235d859cd6ba
THREAD_SHA1_HASH_MOD: 7b58a27a1657f238a46f01f888fd06880593a81a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
DEBUG_FLR_IMAGE_TIMESTAMP: 0
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x124_GenuineIntel_PROCESSOR_CACHE
PRIMARY_PROBLEM_CLASS: 0x124_GenuineIntel_PROCESSOR_CACHE
TARGET_TIME: 2017-12-16T08:19:52.000Z
OSBUILD: 16299
OSSERVICEPACK: 64
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2017-10-25 06:06:03
BUILDDATESTAMP_STR: 160101.0800
BUILDLAB_STR: WinBuild
BUILDOSVER_STR: 10.0.16299.64
ANALYSIS_SESSION_ELAPSED_TIME: 4d2
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x124_genuineintel_processor_cache
FAILURE_ID_HASH: {4c8f3f5e-1af5-ed8b-df14-d42663b1dfa7}
Error: Empty Path.
Machine Name:
1: kd> !analyze -v
Arguments:
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
DUMP_TYPE: 2
BUGCHECK_P1: 0
CPU_COUNT: 4
CPU_MHZ: 8a0
CPU_FAMILY: 6
CPU_MODEL: 4e
CPU_STEPPING: 3
CURRENT_IRQL: f
STACK_TEXT:
OSBUILD: 16299
OSSERVICEPACK: 64
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
ANALYSIS_SOURCE: KM
Thanks
