When gaming display goes black, long beep from speakers. Fan still running
CosmicRustle
47
My old motherboard was causing Kernel-41 errors a lot when gaming (I asked here about that) and so I bought an MSI gaming 970 motherboard.
Now after I've been gaming for a long time, the display just turns black, and I get a constant beeping noise from the speakers, but the pc is still on and all the fans are still running.
Back with the Kernel-41 issue the pc would then shut down after a few seconds of black screen, but this is different and the pc does not shut down at all. It just stays black screen and beeping noise.
The event viewer is showing a kernel-41 which is just me holding down the power button to turn off the pc as it is unusable in this state.
Please help. I fear its the GPU but I hope not.
Spec:
MSI 970 Gaming
Gigabyte Nvidia Geforce GTX 970 (oc out of the box)
AMD FX-6350
Aerocool integrator 600w psu
*Also I'm connecting the monitor with HDMI is this is an issue. Thanks
Yeah i know its not amazing but before when I had my old issue I bought a new psu and it fixed nothing. can't see it fixing this issue outright
GPU temps are good. About 40-60
Cpu temps arent the best to be honest. Sometimes reaching 60 degrees
And thanks yeah Ill try with old drivers
