Does anything else work in that wall socket? A lamp, for instance?Not ecen a single light from the gpu cpu or anything
https://pcpartpicker.com/list/z9WBzfWhat are your full specs?
Is the switch on the back of the PSU turned ON?
The switch in turned on yes,there is nothing in the wall socket with the power cord tho however I do have other multiple things plugged into my other socketsDoes anything else work in that wall socket? A lamp, for instance?
NO' Would that be necessary?Are your front panel connections properly connected?
You need to verify functionality of that wall socket.The switch in turned on yes,there is nothing in the wall socket with the power cord tho however I do have other multiple things plugged into my other sockets
Well I know the functionality of the wall socket is fine my surge protector was plugged into it beforehandYou need to verify functionality of that wall socket.
Plug something else into it...anything else.
'beforehand'Well I know the functionality of the wall socket is fine my surge protector was plugged into it beforehand
after checking the wall socket functionality the PSU switch and cable,It still doesn't work'beforehand'
I'm just trying to ascertain the actual functionality.
Does it work NOW?
You are the only one with eyeballs on the situation.
After that, you work inwards:
Socket
cable
PSU switch
etc....
Then you move inwards.after checking the wall socket functionality the PSU switch and cable,It still doesn't work
It still won't turn on I've touched and verifiedThen you move inwards.
Verify ALL the cables from the PSU are properly connected.
Not just look...touch and verify.
I would show u a a picture of a build but I don't know how to post itDid it ever work?
Upload your pic to imgur.com, post the link here.I would show u a a picture of a build but I don't know how to post it
He still hasn't answered the original question as to whether or not anything else plugged into that wall plate works.And we out here really can't tell.
Either something is not connected properly, or something is broken.
How did you check the wall socket?after checking the wall socket functionality the PSU switch and cable,It still doesn't work
