When I turn my PC on it says new CPU installed? (HELP)
TheHazzaaHD
131
Hi guys,
Okay so here's what's happening. Around 1 in 3 times that I turn my computer on it will say a new CPU has being installed, press F1 to run setup. Then I have to go into the setup and reconfigure it again, then save and exit.
This is really frustrating as I haven't installed a new CPU in my computer EVER. I've had this custom made PC for around 2 years now and it's only started doing this recently. So do you know how to fix this?
Thanks.
UPDATE [FIX]: I have resolved the issue. Basically all I did was update my BIOS and now
everything is fine again :)
UPDATE [AGAIN]: After around 2 weeks after the orignal fix the PC began to lose it's date and time settings and I had to recover my BIOS every time I turned my PC on. To fix this I installed a new CMOS battery and now everythings fine :)
I resolved the issue. I updated my BIOS and now everything's fine 😀
That's great! What version of BIOS did you have?
I had Version 1708 BIOS for the Asus P8Z77-V and I updated to the Version 2104 :)
