S shibasankar1997 May 19, 2018 1 0 10 May 19, 2018 #1 In the 18% of the battery it will automatically shuts down without warning messsage...and after pluged in it will cgarged upto 85-90% only.....any solution for this problem
Solution webworkings May 19, 2018 Sounds like you may be in need of a new battery soon. They will often do just that when they are going bad.
webworkings Titan Apr 6, 2016 11,201 0 86,610 May 19, 2018 Solution #2 Sounds like you may be in need of a new battery soon. They will often do just that when they are going bad. Upvote 0 Downvote Solution
