Question When playing MC or Valorant on my 2080, I get lower fps than my old 970.
Jul 26, 2021
When on Valorant my fps is lower than what I got on my GTX970. I'm now using a 2080.
I have used ddu to uninstall previous drivers.
My cpu load sits around 30%
My gpu load also sits around 30-40%
I wish my GPU load was running around 100% so that I should get more fps.
On Minecraft using shaders, my old 970 used to run over 80fps. Now i'm running 40-50 with the same map, settings, and everything.
Cpu load sits around 30%
The gpu sits around 40.
PC specs:
Ryzen 7 3700X
RTX 2080
16gb 3200mhz cl16 vengeance rgb pro
Asus B450F
750W Gold Corsair Psu
My 970 was running higher frames the hour before I installed my 2080.
Any ideas?
PC specs:
Ryzen 7 3700X
RTX 2080
Asus B450F
Any ideas?
Are your mobo chipset drivers installed/upto date?
Latest posts
