[SOLVED] When speaker volume is low, my headset volume is low as well...
Oct 10, 2019
4
Hi everyone, I have an issue where my speaker volume control in windows 7 also controls the volume of my headset (which I like using at the same time). I have to set my speaker volume to 100% in order for my headset to be at max volume even if they are at 100%, they are not as loud as when i adjust my speakers to 100%, it seems that the audio controls are connected together even though I want to control the volumes separately if that is even possible. I just want my headset at full volume and my speakers at low volume, if I also mute my speakers my headset is muted as well and can't seem to figure out the problem. If it helps my headset uses optical and is a Tritton Pro+ 5.1 headset. My speakers are made by Creative (not sure of model exactly) and they use the motherboards audio inputs which are orange, black and green. Any help is greatly appreciated. Thankyou.
