When the Blue Yeti is connected there's no sound
snakehead97
41
So yesterday I bought a Blue Yeti microphone and I am satisfied with it. However I have one huge problem. The yeti is plug and play so when I plug and record it the sound is fine. However I can't hear any other sound because my speakers aren't working. The moment I disconnected the Yeti the Speakers worked. So I came to a conclussion that the speakers only work when the Yeti isn't connected. It's really frustrating. Anyone know how to fix it?
EDIT: I've been messing around with my PC to find out what the cause of the problem is and I found out that the Yeti when connected not only automatically acts as a default microphone but also acts as a default speaker because of the 3.55mm earphones port. Any idea how to bring back my DELUX speakers as default?
Thank you in advance.
I'm sure that you've fixed this by now, but in case not, RIGHT CLICK on the SPEAKER ICON at the bottom right of your screen. Choose PLAYBACK DEVICES then scroll down to your mic input/device in the list and choose SET AS DEFAULT. There may be a few inputs listed. If the sound doesn't work with the first one find the correct one by trying each one at a time. Good luck!
