Hi
I've been reading about sound cards and for what purposes one would need them and basically came up with that if I'm using high end speakers I would benefit more from having a sound card installed.
So my question to you is this;
I'm buying Harman Kardon Nova speakers (I'll list the specs down below). Would I benefit much from having a sound card installed?
BTW, my motherboard is Asus Maximus Hero VI.
The specs for the speakers:
Specifications
• Power supply: 19V DC, 3A
• Power consumption:
57W maximum, <0.5W eco-standby mode
• Speaker channel number: 2
• Transducers: 2.5’’(63mm) for woofer, 1.25’’(35mm)
for tweeter.
• Amplifier power: 2*20W woofer+2*20W tweeter
• Frequency response: 70Hz - 20KHz
• Signal-to-noise ratio: 85dB at rated power (A-weighting)
• Bluetooth® transmitter frequency range:
2.402 - 2.480gHz
• Bluetooth® transmitter power: Max. 4dBm
• Bluetooth® transmitter modulation: GFSK,
π/4 DQPSK, 8DPSK
Thanks in advance for your opinions
Specifications
for tweeter.
2.402 - 2.480gHz
π/4 DQPSK, 8DPSK
