[SOLVED] Where Are The System Fan Headers?
Read motherboard manual. Page 1-2.
There are 2x 4pin cpu fan headers, 5x 4pin chasis/pump fan headers + 1x 5pin ext fan header on the motherboard.
https://www.asus.com/us/Motherboards/ROG-STRIX-Z390-E-GAMING/HelpDesk_Manual/
I have 6 fan cables that need to be plugged in they are all 4 pins which ones do I use? I already plugged in the cpu cooler
Then you will have to use a fan hub or fan splitters.
Oh good. I am now a little stressed I will be back
so I have the ll120 and it has 2 cables that needs to be connected. I have 2 of the fans rear and top so that is 4 cables. also 2 nzxt 120mm fans included on front. I don’t know where to put them really there is no thing as a SYS FAN header there are cha fans and some other idk. I couldn’t find anything related to connecting case fans on the manual. Should I contact asus or can you help me. btw how do I use pliers to fix a broken pin should I just try to bend it back?
