The Lenovo H520S uses a TFX size power supply. I found conflicting information as to whether Lenovo uses their 14 pin proprietary motherboard connector or the standard 20+4 pin. If you have a 24 pin header for power on your motherboard, the PSU will plug right in. If, on the other hand, you have the 14 pin motherboard power connector, an adapter like this
24Pin to 14pin Power Supply ATX Cable for Lenovo would allow a standard TFX PSU to work in there
Are you looking to upgrade power to add a graphics card or just looking to replace the PSU with something that'll get you up and running?
