Question Where can I buy a replacement USB front panel connector? p500A case.
Aug 12, 2023
It was storming outside, so I turned off my PC until the storm was over. Which I have been doing for 2 years now. Upon re-plugging my PC back up I got an error saying ''USB over-current detected system will shut down in 15 seconds''. After some troubleshooting I figured out one of the USB front panel connectors (not the motherboard port itself) was causing it. I guess it shorted or something during me turning my PC off? I unplugged the offending cable and have just one USB connector plugged into the motherboard. Is there anyway I can buy a replacement USB front panel connector or maybe an extension? I see Phanteks sells this on their website for the p500a. The DRGB I/O Panel
Would this fix my current issue?
I wonder what could have caused the cable to just not work? It was fine prior to me shutting down and unplugging my PC. And as far as I could tell whilst troubleshooting the motherboard USB ports themselves were just fine.
