[SOLVED] Where can I get a replacement for a PS4 Disk Drive ribbon cable?
Aug 3, 2017
13
I purchased a PS4 that needed its thermal paste changing, however I think i torn the big ribbon cable that goes into the disk drive, I have taken the cable off but just need to find where i can get a new one.
The ribbon cable has this text on it: AWM 20706 105 C 60V VW-1
I found a replacement that looks the same as my ribbon cable and says it is for a PS4 however the text is slightly different on it:
2 images of the cable:
View: https://imgur.com/a/83ED4Mr
The two Flexi cables are for the Blu-ray drive, easy to find replacements on eBay. The HDD in the PS4 use standard sata connectors.
Teardown here. https://www.ifixit.com/Guide/PlayStation+4+CUH-1200+Entire+Console+Disassembly/52475
Thanks for the reply but i already looked on ebay and thats where i found the ribbon that looks like mine but with different text on it so i didnt know whether that would work or not. I cant find my exact cable and im hesitant to put one in that is different to the one in my ps4
