N noahlsmith2006 May 6, 2018 5 0 10 Jun 21, 2018 #1 I have the asrock a320m-dgs and i've just bought a new corsair case but I can't seem to find where to plug them in! Can anybody help?
Solution Barty1884 Jun 21, 2018 Page 12 of the manual https://www.asrock.com/MB/AMD/A320M-DGS/index.asp#Manual Points 15 & 20 are Chassis Fan headers. Bottom of the board, near the middle & at the middle of the board, to the left of the CMOS battery. You only have 2x chassis fan headers + the CPU fan header on that board. 3pin fans can connect to 4pin headers, just using the 3 leftmost pins.
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jun 21, 2018 Solution #2 Page 12 of the manual https://www.asrock.com/MB/AMD/A320M-DGS/index.asp#Manual Points 15 & 20 are Chassis Fan headers. Bottom of the board, near the middle & at the middle of the board, to the left of the CMOS battery. You only have 2x chassis fan headers + the CPU fan header on that board. 3pin fans can connect to 4pin headers, just using the 3 leftmost pins. Upvote 1 Downvote Solution
