I purchased the MSI MAG CORELIQUID 240R V2 AIO CPU Liquid Cooler to help with cooling. I have the Asus Prime H610M-K D4 motherboard but the only headers I see on it are the CPU_fan and CHA_Fan, there is no header for the PUMP ?
Okay thank but where should I plug the radiator fans in could I purchase a splittle and have to them plugged into the CPU Header ?Not all MoBos have dedicated PUMP header. In this case, connect the cable from AIO to CPU_FAN header.
Awesome thank you.AIO manual, page 14;
* either connect the rad fans to CHA_fan header (by also using Y-splitter, named "T" in manual)
* or connect the rad fans to PSU's MOLEX connector, by using adapter named "R" (you still need to use Y-splitter)
