Where do I connect the front panel connectors on my prebuilt motherboard?
DrNomienom
I moved my prebuilt motherboard on the Acer Predator G3 710 to a newer NZXT S340 case. I am having some trouble finding where to connect the front panel connectors. I can't find any manual on the motherboard and there's no words or color codes on the motherboard that can help at all!!
Here are some pictures:
A wider look at the side where I think the front panels should connect: http://i.imgur.com/q3jW2Sm.jpg
A closer up of where I think the front panels should connect:
http://i.imgur.com/Nw46hTO.jpg
The NZXT S340 case front panel connectors: http://i.imgur.com/iJrnXRJ.jpg
And finally, the original plug from the predator case that I believe is the front panel connectors: http://i.imgur.com/0STEaBG.jpg
Please help!!
That looks like the right motherbd connector all right.
This is all I could find in a quick search, your connector is upside down from their image. Keep in mind that n= negative and p= positive and you should be all set.
I am having this same exact issue except i moved everything to s340 elite case. There is a plug labeled hdd led, power sw, +p led, and -p led. I can find no manual on the mobo. Can something please tell me the order, orientation and starting point?
