E EireSionnach Distinguished Apr 15, 2015 46 0 18,530 Aug 26, 2015 #1 I'm building my first gaming pc and i ran into a little bit of a problem. I don't know where I'm supposed to connect my led powe cord. please help. my mother board is the asrock h97m micro atx anniversary
Solution S S SiNxPride Aug 26, 2015 it should be where you plug in the power/reset button on the botton of the board somewhere. Check page 18 of your manual to see how to plug them in.
S SiNxPride Reputable Jul 31, 2014 136 0 4,710 Aug 26, 2015 Solution #2 it should be where you plug in the power/reset button on the botton of the board somewhere. Check page 18 of your manual to see how to plug them in. Upvote 0 Downvote Solution
B boosted1g Titan Jun 12, 2013 14,847 9 81,765 Aug 26, 2015 #3 If you are referring to the led lights on your case it will tell you in your motherboard manual. Upvote 0 Downvote
gergguy Honorable Oct 12, 2013 214 0 10,710 Aug 26, 2015 #4 Looking at a picture of it... It appears to say "PLED" on "Pannel1" in the corner of the motherboard by the two SATA connectors. Upvote 0 Downvote
