Question Where do I plug the case fan controller on my motherboard?
Apr 4, 2019
Hi everyone.
I'm new to building a PC and can't seem to figure out where to plug the wire that comes from the case controller. It's a 4 pin connector.
Mobo : B450 TOMAHAWK
Case: Armis AR3 TG RGB
To be honest I tried plugging it to the sys fan1 but either it's the wrong spot or I need to use more force. (I someone said it should go in just fine). It says M/B on the case controller where the cable is connected to so I assume it should connect to Mobo.
Any help will be appreciated. Also I'll provide you with any info I can, just ask.
You would plug the controller into the motherboard, but not the fan header. For RGB your motherboard has specific ports.
See page 38 of the manual.
The fan controller should also be plugged into a fan header. I suggest one of the Pump headers which carry a little more current, just in case.
