Ok so i bought my case and it comes with (1 x Front 120mm Blue LED Fan), (1 x Rear 120mm Fan), and (1 x Top 140mm Fan). The Front fan and the Top fan both have one 4 pin Molex connector and a very small 3 pin plug in each and the rear fan does not have a 4 pin Molex connector but only the very small 3 pin plug in. I know the 3 pin goes into the Motherboard and that the 4 pin Molex connector connects to the PSU but i was wondering will my motherboard be able to handle the 3 fans? I know my PSU will be able to pug up all the 4 pin Molex connectors? It also has an option to where i can use two more 120mm side fans. And also why does the rear fan not have a 4 pi Molex connector? And if it will help you to better answer this here is a link to my PSU, Motherboard, and Case. If you need to know anything else just ask, thanks!
And what is the 3 pin connector named?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153&cm_re=challenger_case-_-11-147-153-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157512&cm_re=ASRock_H97M_PRO4-_-13-157-512-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
