Where does a 1394 cable go?
NBaxter
13
It came with the case and I believe it's to do with the USB 3.0's on the front but I can't find anywhere to put it on my mobo. (Maximus VI hero) would it go In the USB 1314 slot? (The cable says 1394 on it).
Thanks.
There may be an adapter out there to make it work but I doubt you will actually ever need it. It's not to power your USB 3.0 ports. There should be USB plug for that. I expect it's for a firewire port on your front panel which you probably don't need. Firewire is outdated technology. There's very little use for it any more.
Weird I can't find the wire for USB 3.0 on the front loose, I believe it's plugged in but not working. Not a great loss, have more on back just hard to reach. Thanks for the replies.
