Where Does HDDLED, PLED, etc go on ASRock Z97 Extreme4
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Where do they go? All 5 (HDDLED, + PLED, -PLED, POWER, and RESET).
You can download the manual from this link,http://www.asrock.com/mb/Intel/Z97%20Extreme4/?cat=Manual,It will show you how to install the case pin.
Check your MOBO manual, there are a set of pins showing up on the motherboard that are the front panel connectors. You need to check in the manual the labeling of the pins to make sure you plug them in correctly . Dont worry about the important ones Power and reset go either way but the rest have only one way. They wont break though , they just wont work.. FOr example if pled is uncorrecty placed machine should start up but no lights on the front panel will light up indicating it. Just take your time and pace them correctly.
