Where does my 1050 GeForce Gtx go in my build
2010karatekid
I have a B250M Pro VD motherboard and I can’t find the slot for the graphics card to go. Some people have directed me twords the slot but my graphics card is too big.
sizzling
15,173
1,877
The slot nearest the cpu. What do you mean too long, it can't be as its a standard size?
From the picture on the MSI website it shows the slot has a metal shield around it.
mikeywhelan
38
8
If your graphics card is too big you may need to invest in a bigger case.
If the slots are too big, you may have purchased an incompatible graphics card. What graphics card is it?
2010karatekid
If the hdmi port and the ports on the gtx 1050 are pointing twords the outside of the case then the pins aren’t in the same direction as the slot
