Question Where in my MOBO do I connect my PC case's built in ARGB lights?
barkersofgeraldine
152
7
4,585
My PC case is a MSI Vampiric MAG 100R
It has this function called "Insta-light loop" button, which "Quickly control the fan color and lighting effects with Insta-Light Loop at the touch of a button. Click through the profiles at ease and choose a favorite."
I am assuming this controls the built in rgb strip at the front of the case..... as well as any oem pc case fan's installed into the case?
Now where in my motherboard do I connect this?
If the ARBG fans installed on my PC case are connected through a HUB and into the 5v port in the mobo, how do I install my PC case's Insta-light loop so that it can control my pc case fans colors??
The ARBG fans and the PC case are of different brands
Thanks
