[SOLVED] where is my rgb controller in my case?
You daisy-chain HALOS frames together.
Phanteks, on their product page doesn't show or mention any RGB controller.
Your first picture shows a fan hub, however the Phanteks Entoo Pro M doesn't have one included. The picture seem to come from Hardware Asylums review of a Phanteks Enthoo Pro Tempered Glass Edition.
i have read somewhere last year that on the phantek enthoo pro m version (mine is the mid version) , there is a rgb built in hub for my case but i didnt want to put any more fans in so i just left it till now.
this is teh manual that i found:
http://www.phanteks.com/Enthoo-Pro-M-TemperedGlass.html
this mentions the rgb controller. yours and my link of teh manual is the right model but one says rgb controller but the other one doesn't mention it. that is strange.
also that manual you sent only has 1 fan, i got 2 fasn with mine which is the same manual i just posted.
My answers are based on the info you provide.
In post #6 you said you have Phanteks Entoo Pro M (product code PH-ES515P), which can be upgraded with a fan hub.
In post #10 you provide a link to Phanteks Entoo Pro M Tempered Glass (product code PH-ES515PTG), which can be upgraded with a fan hub and some RGB products.
The cases are different models and have different features, however what you ask about are possible upgrades, not included parts. Please read the product descriptions for details.
Reactions: froggy8
hi
i am asking about included parts, have found out that my controller is my power button essentially.
but no way to add more halos on that though.
i must apologize, i should have made sure to have the right model.
many thanks for being patient.
Did you mean this thing?
Floppy power doesn't connect to those.
One end gets connected to motherboard rgb port, the other end gets daisy-chained to next rgb device.
If you force/connect floppy power connector to it, you'll probably burn it down.
i am very sorry, after you said that, i went to check the plugs for the rgb and they are different to the picture i posted.
i just assumed it was that plug.
after i looked around more, there is a spare 4 pin male socket on the rgb cable. i am guessing i will need a female to female adapter to connect more rgb halo?
