C Carg618 Reputable Sep 25, 2015 55 0 4,630 Jan 22, 2016 #1 Where does the power sw and reset sw plugs plug in on the msi 970 gaming motherboard. Pls help
Solution utroz Jan 22, 2016 The manual has it. If you go to the MSI web site you can download it if you don't have a physical copy. http://us.msi.com/product/motherboard/support/970-GAMING.html#down-manual
Threadlight Honorable Sep 10, 2015 68 0 10,660 Jan 22, 2016 #2 The manual that came with your motherboard should tell you where to plug in your power and reset switches Upvote 0 Downvote
utroz Splendid Nov 9, 2010 2,187 3 21,565 Jan 22, 2016 Solution #3 The manual has it. If you go to the MSI web site you can download it if you don't have a physical copy. http://us.msi.com/product/motherboard/support/970-GAMING.html#down-manual Upvote 0 Downvote Solution
