**Where or how can I swap the side panel for my PC build?**
ReUPTurnUP
Commendable
Jun 12, 2016
15
So basically I have a GAMEMAX mid pc case and I it has a small window that is tinted glass (too dark)
Now I've decided I wanted a big window thats clear. without buying a new case is there a website or anyway I can replace JUST the side panel... Thanks!
Side panels aren't interchangeable. Especially among the low end proprietary cases.
Either DIY something yourself, or buy a new case that fits your needs.
Unless it's using a standard tooling (most 'cheap' cases use off-the-shelf tooling from the factory) AND you can identify a compatible chassis with a side-panel you'd prefer...... it's probably going to be cheaper to replace the case outright.
Anywhere that could create you a bespoke panel is going to be making it custom - so losing any benefit of volume etc case vendors get.
I'd imagine a true glass panel, custom made would set you back >$100.... at which point, the sidepanel is more valuable that any Gamemax case...
