Question Where should I plug these Need Help please
May 24, 2020
11
Hi, This might be very stupid so I apologise. This is my very first build. So I have a X570-E motherboard and I got this PC case Enermax SF30 and it has 4 addressable rgb fans but has no manual or anything stating how they should be connected to get aura sync. Once I opened the case I see its all connected to a controller. My question is how will I get these fans to work with aura sync. It would really help if you could spoon-feed me information here please. I have all the pictures
View: https://imgur.com/C30QiCd
View: https://imgur.com/yY1V5Ro
View: https://imgur.com/rbwWMiu
View: https://imgur.com/tv4gbEX
There should be a cable to connect it to the mobo on port five in the mobo photo
View: https://imgur.com/tWeBRl1
I am very sorry I thought I posted this picture with the others. So is that all I have to do just connect the data power and other cable to the rob header.........what about the placements of the fan connectors does that look right from picture1
Wow okay they have a whole mess going on here don't they. Okay it looks they give you a few options of one you can use a usb jumper inside the case to power it and connect it to aura or you can you fan header. But i dont know of any board that supports aura sync via fan header. There should be another option for a cable that connects to the rgb header on the mobo for direct aura symc though
Ya man thats all there is connection wise.....it surely has to have a way to get it working isn't because thats all they gave me and the case specifically states that it has aura sync, mystic for msi and all
Ignore me.... Haha i just completely spaced... So in you mobo box should be a rgb aura cable for your mobo. That should get plugged into the rgb arua port on the mobo the the control board on th back of your case
