Where to buy Scythe 140mm Case Fan 1900RPM
Nevermind42592
79
I realize these have been discontinued but if anyone knows where I can find them or anything comparable please let me know! Thanks! I don't want to spend any more than 20 shipped for one of these fans!
i tried all my sources and came up blank.
Even the classic Matsushita (Panasonic) Panaflo Ultra 120mm x 38mm fan with patented hydro wave sleeve rated at 2,750 rpm, 114.7 cfm, and 45.5 dba is almost impossible to find. It's an oldie but a goodie. Years ago I installed quite a few of those. At the time we didn't care about noise. We just wanted a wind tunnel.
How about the Scythe Ultra Kaze 120mm x 38mm fan rated at 3,000 rpm, 133.6 cfm, and 45.9dba for only $8.95. There are 55 of them available:
http://www.jab-tech.com/Scythe-ULTRA-KAZE-120-x-38-mm-Case-Fan-High-pr-3940.html
I know you wanted 140mm fans but what the heck! Somtimes smaller isn't so bad.
Important stuff - The fans I mentioned are 38mm thick instead of the standard 25mm thicks. Make sure you have enough clearance inside the case. I never had a problem with thicker fans.
