Hi there!
I recently purchased a set of RGB fans, Phanteks SK PWM FAN D-RGB (they actually have only red LEDs) and since this is my first build I have no clue where to connect them since each fan has two connectors (one for the fan power and another one for the LEDs) the motherboard is an ASrock Taichi X370.
The set of fans came with two extra harnesses but I'm not sure how to use them or if I really need them.
https://drive.google.com/file/d/1m5M_-l2JOyJSUg0oIVZTYFLJyPEjCIdF/view?usp=sharing
drive.google.com
My guessing from what I've read in the forums is that I must connect the fans to the power supply and the LEDs to the motherboard, but since I like to control the fans speed I'd like to see if I can keep them connected to the motherboard just as the non LED previously installed fans were connected. (if that cannot be possible then I will need some help for having the fans connected to the power supply, and some help in how to connect the fans LED on the motherboard)
Thanks in advance!
Thanks in advance!
