I have Corsair spec delta which comes with 3 rgb fans in front and 1 normal fan in back and my mobo has only 1 system fan and 1 cpu fan port available.Then where I have connect all these cables in mobo
Most import is that you connect the cpu cooler fan to the cpu fan port.
the other fans go on the system fan por, there should be more unless its a mini itx motherboard.
Int that case you need a hub like this
