I bought a couple different DVI-D to BNC cables and noticed the ones I got tend to ghost when they are in a certain position, I can wiggle them and this can go away till moved again. Im looking for new ones but most cables I find are dvi-a or VGA to BNC.
Do the BNC cables even take advantage of the DVI-A or dvi-I connections?
Is there a place where the cables are good and I wont get any ghosting from wires touching or whatever is causing it when I move the wires around?
Im running at
2340x1440 80Hz right now but it does it when I was running it at 1080p standards and 70Hz too if this matters to anyone.
Im running at
