H hardcorebluesct Reputable Feb 23, 2014 162 0 4,710 Feb 25, 2014 #1 I'm building PC now with asus m5a97 r2.0, sapphire r7 260x 2GB ddr5, and amd fx 8320. So my graphics have 6-pin connector and I don't know where to connect it. Also I have corsair cx 750m power supply if that helps.
Solution W W wortwortwort Feb 25, 2014 Your power supply should have come with 6-pin cables that you can connect to the graphics card.
I IDontUnderstand Honorable Dec 29, 2012 2,377 0 12,460 Feb 25, 2014 #2 If you're asking for where the plug is on the GPU's PCB, then http://www.goldfries.com/images/hwreviews/2013/sapphirer7260x/r7_260x_02.jpg If you're asking for where the plug goes into on the PSU, then http://www.corsair.com/en/cx-series-cx750m-modular-atx-power-supply-750-watt-80-plus-bronze-certified-modular-psu.html It's the cable with 6pin on one side and 8 on the other end, and the cable should go into the 8 pin port next to the ATX plug on your PSU Upvote 0 Downvote
Memhorder Distinguished Jan 10, 2014 1,208 0 19,860 Feb 25, 2014 #3 Should plug into your power supply. Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Feb 25, 2014 #4 There is a matching 6-pin connector that came with the power supply. Upvote 0 Downvote
W wortwortwort Distinguished Jun 1, 2010 291 0 18,810 Feb 25, 2014 Solution #5 Your power supply should have come with 6-pin cables that you can connect to the graphics card. Upvote 0 Downvote Solution
Memhorder Distinguished Jan 10, 2014 1,208 0 19,860 Feb 25, 2014 #6 Card plugs into Motherboard and you should see the 6 pin at back left of card Upvote 0 Downvote
