what is the best place to mount a 360mm AIO in a case? is it in the front of the case or in the top of the case? dose it even make a difference?
the case i have is big enough to mount it either on top or in front so i'm asking this question from the perspective of cooling which is better top or front mount?
You gave nowhere near enough information to even get a answer but you still need one.the case i have is big enough to mount it either on top or in front so i'm asking this question from the perspective of cooling which is better top or front mount?
Mount it on top if available. Most cases that have a 360mm front mount are large enough that there's often issues with getting the tubing mounted down, so it almost always gets mounted with the tubing high, which isn't good for temps nor life of the pump. Mounted top solves many issues there
