Hey!
So,I'm currently in the process of building a computer and I kind of am facing with a bit of an issue with the Cooler Master Silencio 550 tower and the Cooler Master Seidon 120V cooler. So my case has a display like this:
So my problem is that i've heard the radiator should be mounted on an air entrance, to suck fresh air and cool it before it enters. But this particular case has two fans in front pulling air and one on the back expelling hot air. I think there's no way that I can install the radiator on the front because I believe the tubes are too short and i have two massive HDD/SSD grids on my way (although they are removable).
So I'm in a bit of an impasse. Should I install it in the back, expelling hot air, should I revert the airflow, pushing air through the back and expelling it through the front (mounting, in this way, the radiator in the back) or should I install it on the front (and how)?
Also, feel free to jubilate with joy of my glorious paint drawing.
I will be very grateful for any help you can provide.
Nuno.
P.S.: This case is quite new so I'm gonna quickly say the major issues I've had with it. I don't say I regret my buy cause I haven't finished the build and I can't assess that yet. Plus, it was quite cheap and it feels like it has a good quality for price. The back window of quick access to the place of the cooler (for easy mounting) is really small or just poorly placed. I've bought asus maximus VII Gene mobo and after installing it, when I was gonna install the backplate of the cooler, it did not fit through the window and i had to pop the mobo out again. It was a bad mistake by Cooler Master... asus maximus is a pretty popular choice in motherboards so they should have tested it before launching the product. The hole where the PSU cable passes to the back of the case could go a little bit further but that's just a detail cause if u're using a modular psu, the cable will not go through the hole if the psu is screwed in place (you have to pass the cable and then put the psu in place). Those two holes could be extended for like 2 cm and that would not happen anymore. I have no idea about the cooling but the case feels somewhat warm-ish because of the padded front and sides. But that, I have yet to test.
Nuno.
