Question Where to plug fan controller
TheMenace4Life
19
I got a new case that came with preinstalled fans and lights. The controller came with a some new connectors. Where do I plug them? This is an Asus 990fx motherboard. One plug is a 3pin that says vdg in and the other is a a larger 15pin plug that says sata
Lutfij
Can you please mention the make and model of your case? It'd also help in narrowing down the model for your Asus 990FX chipsetted motherboard so we can verify what connectors you have to work with. We've had people misrepresent a connector in the past and ended up frying components = expensive mistake. If you want you can also include pictures of the connector in case you're unsure.
