[SOLVED] Where to plug fan hub ?
May 14, 2022
I have a Corsair 5000D case which comes with a fan hub an my motherboard is a Gigabyte z690 gaming X and I was wondering if anyone knows where the hub needs to be connected ?
A PWM fan repeater controls the included fans, with connections for up to six in total. Reduce fan speed when you want to keep your system quiet, or increase when you want to push its performance, all from a single 4-pin PWM header on your motherboard.
Source: https://www.corsair.com/us/en/Categ...ower-ATX-PC-Case/p/CC-9011209-WW#tab-overview
As of where the fan PWM header on your MoBo is, that you can read from holy bible of PCs (aka MoBo manual), page 21.
And the other cable of PWM repeater (fan hub), is for power. It is either SATA or MOLEX, and connects to PSU.
