[SOLVED] Where to plug in 3 pin connector for RGB?
If you follow through the instructions in the manual, last line in that download link, you will notice a splitter that pairs the 3 fans to one header. The header can then go tot eh front panel of the case or the 4 pin connector can go to a board with an ARGB header. In your case, the motherboard's Digital RGB header is the Adressable RGB header.
Make sure you've got the arrow in the right pin when connecting to the ARGB/Digital RGB header. i.e arrow end goes on pin 1>page 16/point #9 in this manual.
You sure you're not holding a 3 pin fan connector that controls the RPM of the fans...?
Hey guys, so my case (MasterBox MB530) came with 3 RGB fans in the front, I've connected the power to the psu, and now I'm left with this 3 pin connector (My mobo is Gigabyte B450 Aorus Pro WiFi) and I have no idea where to put it( View: https://imgur.com/z1KAtQn
). I also have this cable left from either the fans on the front panel( View: https://imgur.com/BIvHj7D
) Thankyou :)
Omg that wire with the 3 pins is the same one connected to my case that I CANNOT figure out where it goes! I've been googling for hours! Did you ever figure out where it goes?
