[SOLVED] Where to plug in AIO pump and fan without any pump connectors
Jan 11, 2019
Hey. My motherboard, MSI B75MA-P45, has only a CPU_FAN and two SYS_FAN connections as far as i know. My AIO Liquid cooler is a Cooler Master Nepton 240M. My question is, is it safe to plug the pump into a CPU_FAN or SYS_FAN connector? Does it damage the computer in any way?
Best regards, Alfred
Radiator fans should be connected to CPU_FAN and pump to SYS_FAN if you don't have AiO_Pump connector. Header pump is connected to should be set for full speed all the time and shouldn't be shared with an(s). That's quite safe as pump's motor is no stronger than any 120mm fan.
