Where to plug in internal speaker on motherboard, MSI - B250M PRO-VDH Micro ATX LGA1151 Motherboard
masterspammer
12
I have no idea how to install a PC speaker (not a beep error one). I've looked in the manual but can't find anything related to a internal speaker, or its under a different name that I'm just not noticing. Can someone help me out in where I'm supposed to plug it?
Well here's the thing, I had a really old prebuilt computer with a speaker inside of it capable of playing normal sounds and i took it out to try to put it in my new computer
You're talking a very old PC for that to have been the audio solution.
Audio now doesn't work the same. Sound is low level line output, and not enough power to run a speaker.. speakers require some kind of amplifier.
I doubt that the speaker is anything to worry about too much. If you have a sound amplifier, you could use it, just don't expect much.
Oh, yeah it has a sound amplifier do you know how i could install it then?
For more clarification: https://gyazo.com/c7ceac79bc27c241b5541bf2c64475e1
