Question Where to plug in Lian Li rgb controller on ASRock X570 Taichi mobo ?
Jul 16, 2020
I have been having a hard time making sure my Lian Li Uni Fan 120 controller is being plugged into the proper place. So there are 3 cables coming from the controller. One connects to the PSU SATA 15 pin connector. One connect to USB and the third cable splits off into two cables, one saying to connect to fan, the other to 5V ARGB 3 pin header. So the SATA connector should be obvious.
The USB connector can go to either slot 24 or 25 on the mobo that says USB 2.0 header . I can't seem to find the 3 pin 5v argb header and the 4 pin fan. 29 at the bottom of the keyboard is a 3 pin header labelled addressable led header. So is this where the 5v argb portion plugs in and if so where does the 4 pin fan plug in? and am i correct on where to plug in the usb? Any help would be appreciated. Thanks.
Doug
