A a04771 Commendable Jul 31, 2016 22 0 1,510 Jul 31, 2016 #1 ZOTAC GeForce GTX 1070 AMP! Extreme or MSI GeForce GTX 1070 DirectX 12 GTX 1070 GAMING Z 8G Both have the same price on newegg.ca, so I just want to buy the one that has better cooling and less noise. And will both fit my ZALMAN Z3 PLUS case?
Solution Karadjgne Jul 31, 2016 Msi runs quieter and cooler, the Amp! Extreme slightly faster. At stock. The Zalman Z3 Plus will fit a 360mm card. The MSI Gtx1070 Gaming Z is 279mm. Not a problem.
Karadjgne Titan Ambassador Dec 26, 2012 30,759 4,553 142,790 Jul 31, 2016 Solution #2 Msi runs quieter and cooler, the Amp! Extreme slightly faster. At stock. The Zalman Z3 Plus will fit a 360mm card. The MSI Gtx1070 Gaming Z is 279mm. Not a problem. Upvote 0 Downvote Solution
A a04771 Commendable Jul 31, 2016 22 0 1,510 Jul 31, 2016 #3 Karadjgne : Msi runs quieter and cooler, the Amp! Extreme slightly faster. At stock. The Zalman Z3 Plus will fit a 360mm card. The MSI Gtx1070 Gaming Z is 279mm. Not a problem. I am worried about the width of this card. I don't know it my fit in because its too wide Upvote 0 Downvote
Karadjgne Titan Ambassador Dec 26, 2012 30,759 4,553 142,790 Jul 31, 2016 #4 The case is 192mm wide, the card is 140mm wide. It's a pretty standard size ATX mid tower. I don't see any problems. Upvote 0 Downvote
A a04771 Commendable Jul 31, 2016 22 0 1,510 Jul 31, 2016 #5 Karadjgne : The case is 192mm wide, the card is 140mm wide. It's a pretty standard size ATX mid tower. I don't see any problems. Ok thank you for helping Upvote 0 Downvote
