Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
"Bill" <not@home.com> wrote in message
news:EhRkc.51735$oN1.26428@bignews5.bellsouth.net...
> "Buffalo" <eric(nospam)@nada.com.invalid> wrote in message
> news:ETPkc.8522$I%1.732787@attbi_s51...
> > "Andy" <andy@nospam.com> wrote in message
> > news:nbe790tlrug2u6q2jeg6bpl5b721sfhitc@4ax.com...
> > > On Sat, 1 May 2004 04:37:22 -0400, "Bill" <not@home.com> wrote:
> > > >Yes I understand and knew that. My point is with a 250W PSU you can
use
> > the
> > > >9600XT with no problem and no need to upgrade the PSU. The 9600XT
does
> > not
> > > >require a power connection or PSU better than 250W. Other high end
> cards
> > > >recommend 350WPSU and do require a power connection to the PSU
> > > >If he isnt ready or willing to upgrade the PSU then the 9600XT is a
> good
> > > >choice.
> > > >Hope I explained it better.
> > > >Bill
> > > Thanks Bill. That was the way I understood it. (that the 9600XT
> > > doesn't require power from the power supply.) I still might just wait
> > > and upgrade the PSU anyway, then opt for one of the higher end ATI
> > > cards. I just don't want to "waste" my money on a video card that is
> > > also going to be limited by my CPU. (P4 2.5)
> > > Thanks again,
> > > Andy
> > All components in the PC draw their power from the PSU, except for the
PSU
> > itself.
> > Does the 9600XT draw power from wall socket?
> No it draws it from the PSU but you DONT need to run a separate power
> connector like the other high end cards...thats a little wire with
> connectors on both ends..one runs from the card and the other to the PSU .
I
> can draw a diagram if it would help. And like I said it doesnt need more
> than a 250W PSU.
That all depends on how much the other devices draw and what voltage bus the
vid card draws from.
I know about the separate connector
🙁used to take the load off the MB and
supply more power than the MB transformers or circuity can, if needed).
Some MB's draw a lot off their 5v bus and convert it to other voltages.
That 250w PSU is probably too small, then again, you may be correct.
He should probably get a PSU with at least 30amp on the +5.0v bus and 15amps
minimum on the +12.0v bus.
Either way, he will make up his own mind.
