Which cable should i use for 1440p monitor
Yazan Zaid
290
I bought AOC Q2770PQU(1440p overclockable montior) and i want to overclock it to 90hz so which cable should i get? i got r9 290x tri-x+i7 4790k
thats not true, dual link DVI will do 1080@120/144Hz just fine.
if my simple math is correct that would be 10% more data than 1080@144Hz, might work..
Anyways it seems the monitor comes with whole bunch of cables, at least in the EMEA region (thats Europe, Middle-East and Asia), so you shouldn't need to buy any extra cables.
http://www.tftcentral.co.uk/reviews/aoc_q2770pqu.htm
Accessories
Power, DVI, DisplayPort, HDMI, VGA, audio and USB cables
well the cables arent expensive, like 10-15$ each. You've already spent several hundreds so extra tenner is not gona kill you 😛. Just get the DP cable as it is the latest and has the potential for higher bandwidth (also slightly more expensive, but meh)
