Which case for Thermaltake Water 2.0 Extreme?
Thanks for the fast reply!
Quick clarification: will any 2 x 120mm fan mounting area work? Looking at the radiator, I suppose it would... it just comes with bolts to hold it directly to the case. Would just have to have enough clearance underneath and around the sides I guess?
Thanks, very true. Quick search shows plenty of video reviews of the case (though mostly of the full-tower version) but nothing with water cooling that I've found yet. Still good info re. the 2 x 120mm fan mounts, I'll keep looking around for other cases too.
Cooler Master HAF series have room for them, I know i own a 932 full tower, its not to expensive, the haf xm is a mid tower that still has tons of room, just sits shorter than the HAF X, run for 129 CDN last i looked
I7 4820k 3.7ghz
Asus hd 7970
8gbram ddr3
Msi z87 g43 gamming mainboard
500gb hdd western digital
Azza genessis 9000
Coolermaster hyper 212 plus heatsink
Lite on dvd drive
750w coolermaster silent pro 80p plus bronze
I want to make sure that is 750w coolermaster silent pro good power supply for this pc biuld ?
Help me building it for gamming
First time in my life...
I7 4820k 3.7ghz
Asus hd 7970
8gbram ddr3
Azza genessis 9000
Lite on dvd drive
as long as you are not crossfireing, you are fine
Ok thanks
