Which converter box would I want to connect my 2 red/white RCA's from my 1995 Pioneer RX570 receiver to my Samsung Model#UN55
To connect the digital audio output to the analog input of your Pioneer you need a digital to analog converter.
https://www.amazon.com/Easyday-Digital-Converter-Optical-Headphone/dp/B00NJCCAKY/ref=pd_lpo_23_lp_t_4?_encoding=UTF8&psc=1&refRID=B7A40REA65HN7DSXPXR3
Check the TV audio menu to make sure you can set the output to PCM stereo. If not you need to get a DAC that accepts a 5.1 bitstream input
https://www.amazon.com/Parts-Express-Digital-Converter-5-1-Compatible/dp/B00CWELGMS
You will also need a digital audio cable (either optical or coax depending on the TV ) and an RCA stereo cable.
You may have to turn the digital out on and the TV speakers off in the TV audio menu.
